TweakS [8.5.2011] (RU,EN,SK,CN,freeware,S60v3/v5/S^3)
Příspěvekod pyler v pon led 24, 2011 3:10 pm
TweakS
Autor: Kolay & CODeRUS
Licencia: freeware
Kompatibilita: S60v3, S60v5, S^3
Požiadavky aplikácie: H@CK
Homepage: :arrow:
http://kolaysoft.ru/TweakS
Slovenský Homepage: :arrow:
http://kolaysoft.ru/TweakS/index.php?lang=26
Aktualna verzia: 1.12
Jazyk: rusky (RU), anglicky (EN), slovensky (SK), cinsky (CN)
Through this program for Nokia now you can easily change some parameters of the OS on the phones with full open access, which previously were not available for editing and you had to manually edit files in a folder 10202be9. TweakS acts as a shell of plug-ins, each of which represents a set, united under the same purpose. Some settings can be locked into the OS, the program for their detection will perform automatic unlocking and report on the need to restart the device, because Blocked options become available for editing only after a reboot.
Each plug-in keeps a description of the available editing options, so it is recommended first to carefully study its features. All available plug-ins for programs TweakS you can download directly from the program itself, for this you need to connect to the Internet (the weight of each plug-in around 1-2 KB), or the developer's site. If the plugins have been downloaded by you manually, then to install them you just open them via a standard file manager.
To cancel your changes, ie if you want to restore the changed settings to their original condition, you must select a menu item Reset to standard.
Available plugins:
"Kinetics of the menu
"Parameters Recorder
»FM Transmitter
"Backlight (carefully with this setting!)
"Settings menu (for touchscreen phones)
"Settings menu (for push-button telephones)
"Notifier
"On / Off
"System LEDs
"Telephone
"Telephone Applications
"Vibration
Naposledy upravil pyler dne ned kvě 08, 2011 9:46 am, celkově upraveno 30
Re: TweakS [24.1.2011] (RU)
Příspěvekod Benecore v úte led 25, 2011 9:58 am
Oficiálnu ENG verziu vypustia Kolay & CODeRUS až keď budú doladené bug-y aplikácie. Inak celkom zaujímavý nápad táto app :class:
N950 MeeGo Harmattan PR1.2
BlackBerry Dev Alpha B
Ako sťahovať z madlink.sk
• Otvoriť odkaz
• Počkať 5 sekúnd
• Stlačiť SKIP AD vpravo hore
Benecore
Příspěvekod pyler v úte led 25, 2011 2:10 pm
EN verzia 1.03
TweakS 1.03.rar
(119.15 KiB) 213 krát
Naposledy upravil pyler dne pát led 28, 2011 6:32 pm, celkově upraveno 4
TweakS [25.1.2011] (RU)
Příspěvekod prokop v stř led 26, 2011 8:08 pm
K dispozici je verze 1.03 - oprava dialogu při výběru souborů.
Kdo vůbec neovládá ruštinu, tak by možná radši měl vydržet, zítra by tu měla být česká verze, nebo aspoň CZ patch. Mimochodem, ta 1.02 EN od toho Turka je stejně zprasená :evil: Jestli jste jí ještě neinstalovali, tak to radši ani nedělejte. I moje slabá znalost EN stačí na to abych poznal, že je to místy přeložené špatně, a navíc díky idiotskému zvyku některých 'modderů' přejmenovávat aplikace nebude fungovat správně aktualizace.
Ta CZ ale nebude zatím úplmě 100% česky, protože samotné pluginy se stahují z webu autora, a tam jsou zatím kromě těch 3 EN všechny v RU. Počítám že by mohly být časem dostupné i v CZ, ale určitě to ještě nějaký dobu potrvá. Nerusofilové se tedy zatím budou muset spokojit s tím že sem k nim napíšu jen hodně stručný popis nastavení. Existuje jich zatím celkem 15 + nějaké ve fázi alfa a beta verzí, takže myslím že poté se možná najde dost lidí kteří využijí podporu autorů z menu aplikace přes Premim SMS - ta stojí přes české operátory pouhých 10Kč (osobně odzkoušeno u VDF a O2). Otázka je, kolik z toho se nakonec dostane k autorům, ale 'halíře dělají talíře'. A Kolayuk s CODeRUSem si podporu podle mě rozhodně zaslouží :class:
Obecný český popis každého pluginu asi nebude problém dostat do telefonu patchem, ale při každé aktualizaci pluginu se ten popis asi změní znova na ruský. Přitom jen dneska a včera bylo 6 aktualizací pluginů, ale to jsem je ještě neměl přeložené, tak nevím jestli se to na tu RU změní určitě. Podle mě ale změní.
Autor prosí, abychom při rozšiřování jeho softu uvaděli odkaz na homepage aplikace. Takže i já prosím všechny kdo sem budou dávat soft od Kolayuka, aby to vždy dělali.
Ostatně - přinejmenším u freeware je to vždycky dobré, a navíc Kolayuk má tu prosbu u každé své aplikace zvýrazněnou :wink: . Takže případné uploadery freeware softu obecně prosím, aby mrkli vždy na web autora a nereuploadovali pokud to není z nějakých důvodů nutné (kromě neveřejných RC a RC test verzí jsou vyjímkou především podivínští autoři kteří dávají svoje aplikace výhradně jen do jistého zatraceného krámu. V tom případě je podle mě naopak velmi žádoucí z Ovi kvelbu reuploadovat :D )
Takže:
:arrow: TweakS EN verze webu (hodně zjednodušená)
:arrow: TweakS RU verze webu (podrobnější, a taky fórum s dalšími informacemi)
Pro rusofily directlink ke stažení té v 1.03 RU:
:arrow: TweakS v1.03 RU
Zítra by tu měl být ten CZ patch a asi i celá app v CZ + ty další pluginy, ale možná bude lepší instalovat napřed ruskou verzi, pak ruské i EN patche a nakonec patch který téměř vše ruské počeští. Ještě to musím ověřit.
tak je tady další aktualizace (opět verze 1.03 RU, a je pořád pod předchozím linkem).
Opraveny bugy s padáním aplikace v některých situacích na S^3 telefonech, opraven listbox, opraveno pár dalších bugů, zmenšen instalační soubor.
Bohužel jsou ale jazykový soubor i nápověda trochu jiné a budu to muset přeložit celé znova od začátku :evil: Takže si nejsem jistý jestli to tu bude už zítra. A jestli zítra nebo pozítří vyjde další aktualizace kvůli které to budu muset předělávat, tak už se na další dočasný neoficiální překlad vykašlu a budu to řešit už jen oficiálně s autory.Tudíž to bude trvat ještě déle...
Naposledy upravil prokop dne stř led 26, 2011 11:30 pm, celkově upraveno 1
Důvod: Aktualizace aktualizace :)
Re: TweakS [26.1.2011] (RU,freeware)
Příspěvekod pyler v pát led 28, 2011 1:23 pm
EN verzia 1.04
TweakS 1.04.rar
(156.52 KiB) 203 krát
Naposledy upravil pyler dne pát led 28, 2011 6:44 pm, celkově upraveno 4
Příspěvekod MirosPikos v pát led 28, 2011 4:04 pm
Chtěl bych se zeptat, zkouším rozchodit FM Transmitter na mojí E51, má smysl se tím zabývat? Nebo je to nereálné... díky...
MirosPikos
Model telefonu: Nokia E51 410.34.001 hacked
Příspěvekod sat.an v pát led 28, 2011 4:55 pm
to MirosPikos:
pokud si přečteš přesně návod na použití aplikace, zjistíš, že pluginy otevírají pouze vestavěné možnosti telefonu, které nokiáci z neznámých důvodů zatajili. pokud se ti některé možnosti pluginu nezobrazují (nebo se nezobrazí žádná) znamená to, že tvůj mobil tuto schopnost nemá. Aplikace sama zjištuje, co tvůj telefon může.
V vém případě je asi jedinná možnost toto rozchodit: naučit se programovat a vytvořit si vlastní firmware a to ještě jen pokud to umožní hardware telefonu
sat.an
Model telefonu: N81
Re: TweakS [26.1.2011] (RU,EN,freeware)
Příspěvekod pyler v pát led 28, 2011 7:47 pm
Verzia 1.05
Changelog
- pridana oficialna anglictina
TweakS 1.05.rar
(157.53 KiB) 175 krát
TweakS [28.1.2011] (RU,EN,freeware)
Příspěvekod prokop v pát led 28, 2011 9:57 pm
K té v1.05: Changelogy mi už jaksi splývají, ale mělo jít zase o nějaké opravy v souvislosti s S^3 a o další v podstatě nedůležité opravy. Mimochodem, při aktualizaci přímo z aplikace se verze 1.05 hlásí jako 1.04, ale jde jen o drobnou chybičku autorů.
Překlad mám hotový pro 1.04, a opět bude potřeba jej udělat znova (viz edit mého předchozího postu :D ).
Navíc od včerejška přibyly další pluginy a aktualizace 2 stávajících pluginů, ale jak jsem tušil, tak ani překlad krátkého popisu nemá smysl sem dávat, protože se při aktualizaci buď přepíše ruským, nebo prostě nebude fungovat (aplikace ho vnímá jako úplně jiný plugin, hlásí že není funkční a že je potřeba restartovat telefon nebo reinstalovat plugin - což logicky nepůjde). Takže zatím přidávám aspoň soubory ke stažení všech oficiálně vydaných pluginů (neoficiálně ve fázi testování jich je víc) a soubor české nápovědy. To je myslím zejména pro začátečníky, ale i mírně pokročilé symbianisty opravdu důležité si přečíst!!! (viz MirosPikos) A to celý, v podstatě vše je tam totiž důležité. A navíc.... podívejte se do položky '7. Podpora projektu' :D (ten závěr neni moje práce, jen jsem to volně přeložil :D . Kolayuk už je prostě takový, podobné legrácky už jsem viděl v několika jiných jeho aplikacích, a hodně mi to připomíná dalšího geniálního ruského programátora Jurije Bakunina :D . Nicméně - něco do sebe to má, a podal to podle mě dobře, mně osobně se takové vtípky líbí :D . No a pro ty, kdo ty pluginy využiji, určitě nebude potíž to co je v začátku této položky :wink: . Podle mě v je v současné době právě tohle ze strany uživatele ideální cesta jak poděkovat autorům a podpořit je. Otázka je, kolik z toho nakonec autoři dostanou, a proč tak moc cpát do kapes pouhých prostředníků, ale pro uživatele je to myslím nejpohodlnější)
Sorry, ale nemám momentálně skoro žádný volný čas, a v téhle situaci, kdy se aktualizuje v podstatě každý den, bych se asi upřekládal a upakoval :D. Takže zatím je zde jen nápověda k ručnímu nakopírování (podle mě velice důležitá pro začátečníky) + soubory ke staženi všech oficiálně dostupných pluginů:
plugins_help.zip
(29.85 KiB) 230 krát
Soubor Tweaks.h25 rozbalte do E:/resource/help/ . Můžete i do C:/, systém si ho najde ať už je na jakémkoliv disku, ale hodně souborů nápovědy v C:/ = v budoucnu hláška 'Plná paměť'. Na E:/ to nevadí.
Tudíž taková obecná "nápověda k nápovědě": všechny soubory nápovědy ke všem doinstalovaným aplikacím je dobré přesunout z disku C:/ na disk E:/, přičemž je samozřejmě dobré smazat všechny co nepotřebujeme. Tzn že u aplikací kde si nápovědu chceme nechat, tak necháme buď jen *.h25 (=CZ) nebo *.h26(=SK), a pokud je aplikace nemá, tak *.h01 nebo *.hlp (=obojí EN). Ostatní jsou k ničemu, protože....buď prostě nezvládáme hongkongskou čínštinu my, nebo náš telefon" :D (vyjímky bychom asi dokázali spočítat na prstech poslední zbylé ruky zasloužilého truhláře :D ) . Aplikace která umístí do !:/resource/ desítky jazykových souborů nebo souborů nápovědy, a to zejména pokud je umístí bez ptaní na disk C:/, = bez debat prasácky napsaná aplikace. Viz třeba prasečina všech prasečin Ovi Store :evil: (obzvlášť pikantní je skutečnost, že za touhle prasečinou stojí soudruzi ze severu, kteří se závazali že u jimi požehnaných a tudíž draze zaplacených develeporů budou garantovat optimalizaci jejich softu :evil: . Co ale můžeme čekat, když developerům opakovaně posvětí jejich skutečné viry, sami píšou škodlivý software atd... :lol: ). Právě pro tyhle zvěrstva se píšou extra "čistící aplikace" :evil:
Do archívu jsem tedy přidal ještě balíček všech v téhle chvíli oficiálně existujících pluginů, resp. funguje to jako soubory ke stažení těch pluginů. V praxi je nainstalujete tak, že zip archív umístíte kamkoliv do telefonu, otevřete jej (ideální se mi to zdá v X-plore), a prostě jen kliknete na soubor pluginu s příponou .twk. Vše ostatní proběhne víceméně automaticky, stačí jen potvrdit pár souhlasů. Pro jistotu ještě jednou připomínám - jsou to jen soubory které vyvolají stažení a umístění skutečných pluginů, takže je nutné připojení k Internetu (a proto taky budou v RU! Aspoň do té doby, než s autory uděláme CZ nebo EN verze)
Nevím, jestli má smysl dávat sem teď překlady předchozích verzí, nicméně ještě přidávám k ručnímu nakopírování češtinu do verze 1.04 (když už jsem se s tím sr@al od v0.2 a furt takové věci slibuju ... :D . V zásadě pokud nejste majiteli S^3 telefonu, tak je teď víceméně jedno jestli máte v1.04 nebo 1.05. jen to bude trochu obtěžovat s upozorněním na aktualizaci):
TweakS_v1.04.cz.zip
(1.87 KiB) 236 krát
Re: TweakS [28.1.2011] (RU,EN,freeware)
Příspěvekod Benecore v pát led 28, 2011 10:22 pm
Písal som s CODeRUSom a vyjadril sa, že pluginy budú dostupné len v EN/RU jazyku. V žiadnom inom jazyku nebudú dostupné (opoveď na otázku ohľadom oficiálneho prekladu).
BTW: Mám hotový preklad do SK vrátane pomocníka. Keď som sa s tým babral tak to sem dám, ale v podstate je to úplne zbytočné, pretože je to len už. rozhranie, a to dôležité čiže pluginy bude len v EN a RU jazyku.
EDIT //
Preklad vrátane Pomocníka :SK
TweakS 1.05+SK.zip
(337.26 KiB) 218 krát
• Otvoriť odkaz
• Počkať 5 sekúnd
Benecore
Příspěvekod sat.an v sob led 29, 2011 11:53 am
Benecore:
tak to v podstatě znamená, že asi nikdy nebude ani česká verze, páč jsme na IPmart-foru s Generym trochu tlachali a pluginy používají nějaké zvláštní kódování textu, nebo mají soubory zašifrované. no prostě to s překladem nebude jednoduché.
Ale když máš s nimi takový dobrý kontakt, tak bys mohl vyzvědět, v čem tam mají háček.
sat.an
Model telefonu: N81
Příspěvekod Benecore v sob led 29, 2011 12:03 pm
Češtinu robí Prokop takže čeština aplikácie bude. :)
Ja komunikujem vačšinou s CODeRUSom hlavne kvôli niektorým jeho patchom ktoré my nefungujú na N96 atď.. :cry:
Aplikáciu a uživateľské rozhranie programoval Kolay tak možno on by súhlasil s ofiko prekladom aplikácie do :SK :CZ , ale jemu som nepísal. V podstate je preklad "ako som už spomenul" aplikácie zbytočný, pretože to najhlavnejšie v nej sú pluginy a tie programuje/píše CODeRUS. :inot:
Keď som s ním včera písal tak sa dosť jasne vyjadril, :naughty že pluginy budú dostupné len v EN/RU. Určite svoju prácu chráni, ale ako to som sa ho nepýtal. Možno :t sa bude dať preklad pluginov spraviť ( neskúšal som ), ale kedže na ich serveri budú pluginy len v en/ru tak ako písal Prokop po aktualizácii to bude zase pasé
EDIT : // Ten preklad pluginov, neviem nehral som sa s ním.
Súbory sú podľa čísla (System\Apps\TweakS\Plugins\plugin.plg - v X-Plore kláv. 8 na plugin ) toho daného pluginu uložené v private\10202be9\persists, ale či tieto súbory obsahujú aj texty ktoré vidno v aplikácii to neviem (ale pravdepodobne áno).
*.cre ( central repository files ) sú to skompilované txt-ové súbory ( vačšinou UTF16 )
http://library.forum.nokia.com/index.jsp?topic=/Nokia_Symbian3_Developers_Library/GUID-53E5C9EA-0A38-54A1-AE24-95B71BFFB4B5.html
Naposledy upravil Benecore dne úte úno 01, 2011 1:24 pm, celkově upraveno 6
• Otvoriť odkaz
• Počkať 5 sekúnd
Benecore
Příspěvekod pyler v sob led 29, 2011 12:14 pm
hmm... tak ked pluginy prelozis do SK a budu suhlasit aj autorovia tak daju oficialne SK pluginy na homepage stranku a pri stahovani pluginov cez apl. by bola moznost volby v akom jazyku chcem stahovat pluginy
Příspěvekod pyler v ned led 30, 2011 9:24 am
Verzia 1.06
TweakS 1.06.rar
(168.53 KiB) 192 krát
Naposledy upravil pyler dne čtv úno 03, 2011 2:51 pm, celkově upraveno 1
Příspěvekod nobody v ned led 30, 2011 9:27 am
1.06 nefunguje korektne, pada pri tahani pluginov ikona aplikacie obsahuje otazniky.
E71 FW 500.21.009 (hacked)
HTC Desire
ASUS EeePC 1201n
nobody
Model telefonu: E71 + HTC Desire
Příspěvekod Benecore v ned led 30, 2011 10:05 am
Mne začala včera padať aj 1.05. Inak fungovala normálne. 1.06 tiež padá. Možno robia súdruhovia niečo so serverom :D Pri vypnutí internetu aplikácia nespadne.
• Otvoriť odkaz
• Počkať 5 sekúnd
Benecore
Příspěvekod pyler v ned led 30, 2011 1:43 pm
Pluginy v SK na
Verzia 1.07
TweakS 1.07.rar
(175.08 KiB) 208 krát
Re: TweakS [31.1.2011] (RU,EN,freeware)
Příspěvekod pyler v pon led 31, 2011 7:40 pm
Verzia 1.08
TweakS 1.08.rar
(179.85 KiB) 226 krát
Verzia 1.09 (thx nobody)
TweakS 1.09.rar
(176.95 KiB) 228 krát
Naposledy upravil pyler dne čtv úno 03, 2011 2:42 pm, celkově upraveno 1
Re: TweakS [31.1.2011] (RU,EN,freeware,S60v3/v5/S^3)
Příspěvekod nobody v stř úno 02, 2011 9:50 pm
Verzia 1.09
http://www.kolaysoft.ru/TweakS/update/TweakS.sis
HTC Desire
ASUS EeePC 1201n
nobody
TweakS [3.2.2011] (RU,EN,SK,CN,freeware,S60v3/v5/S^3)
Příspěvekod mtaudy v čtv úno 03, 2011 9:23 pm
Zdravím. Jak se dá nastavit jazyk aplikace ?,píše se tu že od verze 1.07 je to i ve slovenštině,ale ať udělám update,nebo to stáhnu odsud nebo z ofiko stránek,pořád to je anglicky. Díky
mtaudy
Model telefonu: Nokia n9
Re: TweakS [3.2.2011] (RU,EN,SK,CN,freeware,S60v3/v5/S^3)
Příspěvekod nobody v čtv úno 03, 2011 10:49 pm
Nastav si jazyk mobilu na slovencinu. ;)
HTC Desire
ASUS EeePC 1201n
nobody
Příspěvekod Benecore v pát úno 04, 2011 8:00 am
Alebo premenuj koncovku súboru \resource\apps\TweakS.r26 na TweakS.r25 . Prípadne zmaž všetky 3 r01, r16 a r31.
• Otvoriť odkaz
• Počkať 5 sekúnd
Benecore
Příspěvekod pyler v pát úno 04, 2011 8:00 pm
Verzia 1.10
stahujte z homepage alebo akualizujte v aplikacii :-D
Příspěvekod vmonkey v pát úno 04, 2011 8:09 pm
Když tam už je ta Slovenština...neuvažuje se o češtině?
Nokia e51 v410 hacked
vmonkey
Model telefonu: Nokia e51 v410 hacked
Příspěvekod pyler v pát úno 04, 2011 8:29 pm
ak ju spravis....ale podla mna nie je nutna cestina ked je slovencina a anglictina
Příspěvekod pyler v úte bře 08, 2011 1:37 pm
TweakS 1.11
stahujte z homepage :-D a na homepage najdete aj TweakS Creator ( v RU ) a all cenrep key (zaujimave :-D)
// CODeRUS prelozil TweakS CreatoR do EN tak tu je par screenov:
stiahnete ho na homepage ... a s tymi dokumentmi all cenrep key (tiez stiahnete na homepage) si mozte vytvorit vlastny plugin :D
TweakS [8.3.2011] (RU,EN,SK,CN,freeware,S60v3/v5/S^3)
Příspěvekod flibor v ned kvě 08, 2011 6:41 am
TweakS 1.12
- úpravy pro S^3
- padá při spuštění na E52 (předchozí verze nikoli)
Re: TweakS [8.5.2011] (RU,EN,SK,CN,freeware,S60v3/v5/S^3)
Příspěvekod janci.p v ned kvě 08, 2011 6:36 pm
mam n8 a urobil som tam nejake zmeny, ale vobec nic sa nezmenilo..
//added by prokop/: Tak si tu N8 vyplň do profilu jako většina ostatních. Nebudešto muset psát, každému to bude jasné :wink:
janci.p
